How do I make my 32-bit pc to 64-bit?
Solved by Kilrah,
Well do the test already to make sure it's not a problem with you making the USB and booting off of it, if so yeah, probably motherboard change, but then it makes no sense buying a motherboard for a 12 year old CPU unless it's almost free, so at this point it'd be replace everything
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards3 -
1
2
1
4
john b ·
Posted in Phones and Tablets3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
