Search In
  • More options...
Find results that contain...
Find results in...
Need help with a cooler for 12700k
11 minutes ago, johnt said:
What's your budget? ~$40?
50 max im about to post my build list for feedback
I have the 12700k and even with a 240mm rad and static pressure fans, it still runs very hot. Like toasty, toasty hot. I am generally sitting around 60C in gaming even when the CPU usage is minimal. Granted I am using a mini ITX case, and the fans are pulling ambient air into the case, but it's still warm compared to my older 5820k. That's a tough budget for cooling this chip. I mean technically you can run this chip up to ~95C without any issues, but the problem is letting all that heat go into your room.
yes i am gonna get that cooler for a month until the artcic freezer 2 comes back in stock or i can find a better one in 30 days
 Share
