Does the "W/mK" matter on cooling low powered components, phones, or LED strips?
1 hour ago, Newblesse Obblige said:conductivity is the W/mK of the thermal pad?
temperature gradient is the difference between the temperature of the object to be cooled and the heatsink?
surface area is how big is the surface area I will be cooling?
thickness for conduction is thickness of the thermal pad?
So I could get away with a cheap thermal pad on the low power part? I see...
Yep on everything. You can also easily test this with a cheap pad and a "good" 12W/mK pad. You likely won't see any difference on the stable temperature of the thing. If you're choosing pad thickness: as thin as you can go while still getting full contact (thermal paste is better than pads because the paste thins out to almost-nothing)
It's not so intuitive but for heat transfer to happen there has to be a temperature difference. It's why if you place a bowl of water within a pot of boiling water, the water in the bowl won't boil...because the heat transfer goes to zero before the water in the bowl reaching boiling point (one of those trick questions... https://physics.stackexchange.com/questions/649146/cup-of-warm-water-suspended-in-a-pot-of-water-held-at-a-steady-boil)
For stuff like watercooling it's completely linear and why you'll hear "delta T" so much. "a 240 rad can handle 300W at delta T [water temperature vs. air temperature] of 20 degrees" or something like this...which tells you it'll handle 450W if your system can tolerate a ambient + 30C water temperature.
(this is all like physics 101 level....the 401 level is crazy shit about Fourier equations and by that point in my college career I had no fucks left to give so I don't remember it: https://en.wikipedia.org/wiki/Heat_equation ... nowadays everyone just plugs this shit into CAD software to do the modeling and math for them)
