Will this keyboard build sound good?
Solved by Xiee,
Gat milky yellows are indeed budget thoccs, but they sound nice. Used them all on my personal builds. If you want more thocc, consider putting some films in the switches or put some padding inside the keyboard. I have friends who built GMMK pro boards who had to put in some dampening foams in the keyboard to reduce the "pinging". But it's not the same for everyone so try observing how your keyboard sounds when you get it.
