Need help with ram speeds - 2x 32GB Ram 3600 OC with a Z390-E
Solved by Hairless Monkey Boy,
1 minute ago, Heliian said:Just had a quick look at your mobo qvl for memory and they never validated it with 32gb modules of any speed.
You could try to manually input the timings in bios and see where that goes.
Oh yeah, I didn't notice it was 32GB modules. For some reason I saw 16GB upgrade to 32GB, but now I see that the upgrade is to 64GB.
In that case, this will be quite a strain on the IMC. So my comment on a "weak IMC" may not be warranted.
I have the same recommendation, though. Update the BIOS and check the VCCSA and VCCIO voltages. I doubt it is, but if the motherboard is setting them relatively low, then it might make sense to try increasing them manually. My Z390 Asus board always set them too high, though.
