Where should I plug in my WiFi Extender?
lerodemmy
As you can see in the photos, I have two outlets near my PS5 and I’m trying to determine which would be best to plug in a TP-Link WiFi Range Extender.
In the first photo, the outlet is about 3-4 feet in front of the PS5, and maybe a foot lower than it.
In the second photo, the outlet is a little bit higher than the PS5 and about a foot behind it.  It is, however, on the other side of a wall.
These locations are about 15-20 feet from the router.
CPUIntel Core i9-14900K I GPU: EVGA RTX 3090 FTW3 Ultra Gaming I MotherboardAsus ROG Strix Z790-E Gaming I RAM: Corsair Dominator Titanium 64GB I SSDSamsung 980 Pro 2TB I PSUCorsair RM1000x (2021) I Cooler: Corsair iCUE Link H150i I CaseCorsair 5000D Airflow I FansCorsair QX120 x10 Cables: Corsair Premium Individually Sleeved Keyboard: Corsair K100 RGB I MouseCorsair Nightsabre Wireless Mouse Pad: Asus ROG Sheath Monitor: Aorus FV43U
Both locations should result in equal performance. My current WiFi extender is also about 15 feet away from my router and its working just fine 🙂
It is also beneath my desk and is about a foot away from my rig and about 5 feet away from the work laptop. No issues on connectivity from both devices.
CPU : Intel i5-12600K
Motherboard : ASUS TUF Z690-PLUS WIFI D4
RAM : Corsair Vengeance RGB 3200MHz CL16 (2x8GB)
AIO : Corsair H100i 240MM
GPU : Asus TUF RTX3070
Case : ThermalTake Core P3
Keyboard : D60 HHKB with Jwick Ultimate Black switches, G81-3000SAV PBT keycaps
Mouse : Logitech G Pro Wireless
Audio : Edifier R1280DBs | Sennheiser HD598
Thank you!
Why do you need a WiFi extender at such close range? It's not going to do much better than the console's built-in antenna, and extenders always add latency and cut your speed (unless their backhaul to the main router is wired or has a dedicated wireless channel).
I agree that both outlets should work fine, but do you need a Wi-Fi extender 20 feet from your router? If there's poor reception at your PS5, you might want to check for interference in your apartment. We had an old microwave interfering with the Wi-Fi signal, and a repeater didn't help us
29 minutes ago, lerodemmy said:
Dude, that desk is awesome.  Kinda neo-victorian.
It must be true, I read it on the internet...
