Search In
  • More options...
Find results that contain...
Find results in...
Computer boots with GPU fans at full speed, no display
So my PC turns on but doesn’t output video, just a black screen. GPU fans are running at full speed. The weird part is if I turn it off and on a few times sometimes it will randomly work and it lets me into windows just fine as if nothing happened. Gaming is fine too, the GPU appears to function normally.
I am on windows 11. Specs:
i7 8700k @ 4.9ghz 1.34v
MSI z370 SLI Plus
RTX 2080 Ti overclocked
cooler master V750 gold psu
16gb 2666mhz Ram from hyperx
I have tried:
reseting the bios from within the bios(I have not removed the cmos battery yet)
Any ideas what could be wrong?
I'm A Rebel.
Remove the cmos battery.  Could be GPU related.
Cleared the cmos, still happening.
I'm A Rebel.
Do you have another GPU you could try?
 Share
