New network card and router, network speed is slow on PC but fast on phone
Solved by Bombastinator,
55 minutes ago, AverageLeo said:Of course
and obviously I tried to restart the PC and router
So if the issue is antenna blockage you can either find and remove the blockage or move the antenna. They make extension wires for external antennas. Main reason to buy one really, though it also makes possible a few other things. You can even buy antennas with stands that already have extension wires. They’re fairly cheap. Not much to em. I suspect the most expensive part is the not-exactly-BNC connection antennas have
