Which is faster: USB 3.0 2.5inch external, or HDD in optical drive slot?
Solved by da na,
Welcome to the forums!
2.5" externals are quite slow compared to even an internal 2.5". Laptop ODDs (CD drives) use a regular SATA connector for data, but a shorter one for power. You can get adapters that go in your ODD bay to mount a HDD, you'll need one of these - they're <$10. Just search "optical bay HDD" or close to that on Amazon/Newegg/eBay, etc. Make sure you get a correct sized one, 9.5 vs 12.7 are the heights (9.5 is more common on laptops from around 2010 and newer)
