Guys why does this 2.5 hard drive enclosure have DC power port
I got this hard enclosure from used market it's working but i want to know why does it have DC port
USB 2.0 (which this is, if you didn't know) has a lower current limit than 3.x, so it was to get around that limitation (most likely).
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
Way back in ye olde days, the USB spec only allowed devices to draw 500mA per port. IDE hard drives needed more than that, so they usually came with a Type A to barrel plug cable along with a Type A to Mini USB plug for data. You'd have to make sure you plugged power in first.
I bet if you open that thing up, you'll find an IDE hard drive with smaller capacity than a modern SD card.
4 minutes ago, Mel0nMan said:
As was said, older USB revisions (2.0B is what you're looking at) had lower power specification and couldn't deliver the power required for a hard drive.
The drive I'm using is 5400rpm does it need more power or it's fine
Spindle speed doesn't have to do with power consumption. You should plug in that power port, I doubt the enclosure will let you power it on without that connected.
yes its work no issues also ST1000LM014 this what i'm using thank you for help
