How can I connect front-panel USB to my motherboard?
Solved by Cyberspirit,
2 minutes ago, Origami Cactus said:Yeah I guess that would be the cheapest and easiest option, to just not use the type-c port. I don't think there is a point of even using adaptors to connect it up, because it wouldn't have the type-C power delivery.
I have two type C ports but I've honestly never used either. If you do need one then you could always just get a hub or an expansion card.
