PC no longer booting, motherboard shows debug LEDs for CPU & VGA ? RAM faulty?
Hi, I have been having quite a stressful morning.
Before i start these are my specs:
Ryzen 5900x
MSI MPG x570 Gaming edge wifi
Corsair DDR4 Vengeance RGB Pro 3600 2x16gb
Rtx 2070
Be Quiet dark rock 4
Corsair RM750x
2 weeks ago I move, since then my pc sometimes got stuck at the VGA debug LED. And on my screen came the "press DELETE to open bios" screen. But the screen was frozen.
Normally I could fix this problem simply by restarting the pc with the case button.
But this morning this did not work anymore. It kept getting stuck on the frozen screen and VGA debug led.
I then took out the graphics card and restarted my pc. This was probably not such a good idea. It wasn't going to boot anyway because the Ryzen 5900x has no internal graphics. After doing this it got stuck on the CPU debug led. I put my GPU back in but it still stuck on the CPU debug led.
After this I tried a few different things.
Checked all PSU cables if they are still seated well.
Reset the CMOS.
Flashed the bios.
Disconnected the GPU and all SATA connectors & front panel io.
But the problem persists.
Furthermore the CPU fan and one of the front panel fans sometimes works and sometimes not.
TLDR: Pc was working yesterday outside of VGA debug hiccups.
After reinstalling the GPU it remains stuck on CPU debug led.
Maybe you guys have an idea what could be causing this. Many thanks.
Your Corsair RAM is the most likely suspect - Corsair RAM, esp the Vengeance line and Ryzen tend to not like each other much and is normally the root of problems like this, well documented as being a real headache among users of Ryzen setups running sticks like yours.
If you have a different set of RAM that's not Corsair, pop those in and give it a try.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
Hello, thanks for your reply. Unfortunately, I don't have another DRR4 lying around. But I will keep it in mind.
Thanks.
Update:
After stripping down the entire PC, and starting again from scratch. The problem was not initially solved. But what I hadn't tried yet, but probably should have, is to remove all the RAM. Now it did get past the first CPU debug led, and not too  surprisingly got stuck at the RAM debug led.
But now i wonder if this is a clear indication that the ram was faulty and its not the CPU or maybe mobo?
I'd bet the RAM is actually OK but doesn't want to work with your system, that's the issue with it.
Seriously, consider a set of G. Skill sticks or at least somehting else and be done with it - If you have an Intel setup those sticks will probrably be OK since they work without issues for Intel setups.
That's probably what I'm going to do. Thanks for the advice. I'll keep you posted.
Yes, please do.
my bet is the ram too, try one stick at a time and see if u can get it to boot
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
16 hours ago, Beerzerker said:
Yes, please do.
I was able to get 2x8gb G.Skill Trident Z (F4-3600C18D-16GTZRX)
Tested it, but unfortunately to no avail.
Also tried to clear the CMOS and flash the bios a few times but also didn't work.
If you have one around, try a different CPU just to rule the one you have out.
I know you probrably don't have an extra chip but if you do it can be used to test with, that's why I don't toss old ones just for the sake of tossing them.
Never know when it may be of use.
