What type of "fan" curve on my Lian Li Gallahad AIO pump?
3 hours ago, Natsukashii said:So I just got my very first AIO on my new 12900k
Got scarred pretty badly imediately as my fans where blasting full speed and my CPU was hovering around 80° idle with the tubes being pretty warm
Had to do some investigating and look up videos for dead aio pump but turns out it wasn't dead at all, it was just turning too slowly at around 1200rpm.
I use a Z690 Gigabyte Aorus Master and the monitoring software SIV allow me to setup fan curve so I turned it up from 1200rpm to 2200rpm and now my fans stays fairly quiet and my idles temps are around 35°
What i'm asking is that is 2000rpm a high number for a pump? seems like it's maximum is around 3342rpm.
What kind of curve should I setup for the pump? My current one looks like this :
The Galahad pump turns off below about 50%, so it wasn't turning at 1200 rpm, the Aorus software is just a piece of shit that does 30% of 3342 rpm is 1200 rpm, but it doesn't read the actual speed of the pump. So your pump was just straight up not running. Just set it to a fixed 60% or so, and leave it, for some reason the Galahad pumps make a whine when running too fast, and you're not going to notice a difference between 60% and 100% speed on an AiO, you only need high pump speeds on long loops that have multiple blocks and radiators.
