Need replacement for my lap top screen. Need help
Paingamesyt
Hello
I have old Lap Top (Dell 3537) with some strange bubbles that appeared for no reason (i think) and that bubble have black circle and when i use force on that place where are bubble screen somehow recovers but still got that damaged bubble think.
Here is picture
IMG_20211031_161636.thumb.jpg.4461dd8590c01ede0769cf40afc0e5d3.jpgIMG_20211031_161631.thumb.jpg.40b96669d80a0f56041ae5841a2ae5ac.jpg
Now i need to buy new replacement for my lap top screen, my lap top display is LTN156AT30. What number do i need to look so that i can replace my display?
I found 1 screen that have same 40pin and same resolution, this display is: B156XW04 v.5
Can this display work for my laptop?
It's best to buy the original. You can contact Dell, who usually can sale spare parts or various grades at various prices (I would suggest the highest grade to avoid dead pixels or minor scratches). See how much it costs, and compare with what you find online, like the AliExpress one.
if the price is similar, then might be worth it to spend the extra few dollars and go with Dell and get it sooner, but it depends on your budget, of course. If you don't mind waiting, and price difference is larger then what you like, then of course, get the AliExpress one.
The reason why you want to get the same panel, is more then the pin number and size, you have the mounting screws position, and size, as well as panel thickness to consider. It's easier and safer to get the exact same model.
