How reliable are old Delta power supplies?
Kuppi
I have this old HP prebuilt PC which i was thinking of using as a game server.
It has a Delta Electronics DPS-460DB 460W PSU. It's from 2011 or 2012, and it wasn't used for a few years
Here's a picture of it
https://i.redd.it/s72n3o0gq1291.jpg
Id personally keep using it. The failure chance is pretty low(I have seen a lot of computers from that era with original psus. Also if it fails you can normally just get a new one, the change of a fire or damage to other parts is fairly low.
several years ago i bought some old used server with delta power supply, still running 24/7 (5-6 years continuously).
