Ideas for better airflow? (fan/radiator placement)
weenuqx
Hi guys! First let me explain...
I have two intake fans at the front running their max speed off of the PSU due to both my CPU fan header and Chasis FAN header being occupied by the pump and fan on the radiator.
I decided to place the 120mm radiator at the back and mount the two intake fans at the front. But after finishing my build and looking at it I quickly realized that I'll have a problem with a good airflow.
What mount suggestions would you guys recommend? I have space for two more fans at the top. Should I move my radiator to the top of the case or add a fan or two instead? What should I do?
I'll buy more Molex connectors for my PSU to power more fans if neccesary.
The airflow from your explanation sounds perfectly fine, so we need more info of why do you think it is inadequate. Is the front panel fully plastic, so the intake fans can't breathe?
Top fans usually aren't necessary, as hot air rises to the top anyways, by itself.
I only see your reply if you @ me.
This reply/comment was generated by AI.
Sounds fine to me. What cpu and GPU do you have? Why are you concerned, specifically?
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
You have a fan directly on the radiator as rear exhaust, correct? If so you should be fine.
If you want extra fans, I would try adding two top intake and keep the front intake as well. That will help feed cool air to the radiator and force air past the GPU and out of the empty pcie slots.
