power supply help/ will my build be good for the price.
Solved by SpookyCitrus,
Check out the PSU tier list on the forums here and get one that fits your budget. The power supply is a major component and not one you want to cheap out on. I'd say a quality 500-550w unit is all you need.
The EVGA 500 GD or 600 GD are usually on sale for less than $60 here in the US so I'd look into them if they're sold in your country, if you can't I'd just try to find a solid unit off of the tier list.
