GAN-based ATX power supply, passively cooled, super efficient and super small
OnePlane
Go to solution Solved by Spotty,
Thread locked, this has already been posted. Please check for existing news topics before posting.
Summary
Very small ATX power supply based on GAN semiconductors provides super high efficient (94% according to the article) power from mains. Single brick does 250W, but they thought of that and allow you to stack power supplies and sync them using a small sync cable between therm (so no more PS_ON hacks!) for more power. Even two smartphone-sized PSUs is smaller than a normal one! Also has detachable AC power socket if you have a custom project (so no more IEC lead extender nonsense).
image.thumb.png.e7ca5ecff2fff8478c8247e4f6bad5bf.pngimage.thumb.png.712be1a95a54a8f7aeb5dcec6eaf019d.png
My thoughts
 If you can multi-stack them it gives you plenty of power to run anything, and with flexible placement you can go pretty wild with custom builds! Would be a bit harder with GPUs and stacking four of them to get 1000W seems a bit silly...
Sources
 https://www.cnx-software.com/2022/05/26/ultra-compact-gan-atx-power-supply-delivers-up-to-250-watts/
Guest
