Nas CPU speed vs. core count
Solved by Bdavis,
The CPU you choose will depend on what you want to do with your NAS. If it's just serving files for windows file shares I would go with the fast dual core. If you want to run apps or VM's go with the quad core.
What is your use case, and how many users will be accessing the NAS?
noidea213 ·
Posted in Graphics Cards1 -
TheNaitsyrk ·
3
12345678 ·
Rummers ·
Posted in New Builds and Planning4 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
7
1
moondogkill ·
Posted in Cooling3 -
1
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
