Diffused White LED strip
CCFC27
I want to put a white led strip in my case (Corsair 4000D), but I don't want one that looks super tacky where every individual led is clearly visible. Is there one that is the length of the case that is reasonably well diffused? I was hoping to fit it at the bottom between the power supply shroud and the glass side panel.
Some examples :
note : Always re-check LED strips voltage & type (5050, 3258, etc) with what your motherboard can use/give first before buyin stuffs. Unless you're like me, powers it using SATA/USB & External Controller, instead of RGB Header.
ARGB Neon Flex
https://www.phanteks.com/Neon.html
Single Color Neon Flex
https://www.amazon.com/White-Light-Input-Length-2-5cm/dp/B07PRYFS34?th=1
LED strip that uses COB. Single color version
https://www.amazon.com/Powered-Daylight-Backlight-Bedroom-Lighting/dp/B08HD3ZSQV
Alternatively, if you are willing to lose flexibility, and don't mind a bit of painting job. You can combine normal LED strip with a diffuser, google "Led Strip Diffuser".
COB Led info :
https://www.vehicleservicepros.com/service-repair/the-garage/ask-the-expert-and-tech-tips/blog/21087718/alert-stamping-mfg-co-inc-ask-the-expert-when-it-comes-to-led-lighting-what-is-the-difference-between-cob-and-smd
https://siliconlightworks.com/resoures/what-are-cob-leds
Refresh before you reply
