Block ads system-wide on Android 9 and above
Guest
Hello,
There's a way to block ads on all apps on Android without additional software and it works on almost all apps and web browsers
Quote
Open Settings and go to the Network and internet section and click "Private dns and select "Private dns provider hostname" and type dns.adguard.com and click on save and after that reboot your device.
Note:- This doesn't work on YouTube because they load the ads directly with the videostream and trying to block them on dns level will break the videostream.
