Search In
  • More options...
Find results that contain...
Find results in...
the 4080 is rumored to be 350w can my power supply run it?
 Share
the 4080 is rumored to be 350 watts, same as the 3090. can my evga 750 g5 run it or will i have to reduce the power limit on it?
Might wanna wait for the card to be released first. We dont know the power characteristics of the cards, they might have transient spike issues like RTX3xxx series cards.
mY s YsTeM iS Not pErfoRmInG aS gOOd As I sAW oN yOuTuBe. WhA t IS a GoOd FaN CuRVe??!!? wHat aRe tEh GoOd OvERclok SeTTinGS FoR My CaRd??
 HoW CaN I foRcE my GpU to uSe 1o0%? BuT WiLL i HaVE Bo0tllEnEcKs? RyZEN dOeS NoT peRfORm BetTer wItH HiGhER sPEED RaM!!dId i WiN teH SiLiCON LotTerrYyOu ShoUlD dEsHrOuD uR GPUmy SYstEm iS UNDerPerforMiNg iN WarzONEcan mY Pc Run WiNdOwS 11 ?woUld BaKInG MY GRaPHics card fIX it?
 MultimETeR TeSTiNG!! aMd'S GpU DrIvErS aRe as goOD aS NviDia's YOU SHoUlD oVERCloCk yOUR ramS To 5000C18
3090 has recommended spec of 850W for a good reason, in case of 4080 I doubt that 750W would do well, in large part due to how Nvidia designs their GPUs, with little control over peak/short term load.
But we shall see how it turns out.
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
actually the 3090 recommends 750, its the 3090 ti that recommends 850.
750. My little SFX 750W has powered my 3090 @ 400W for almost a year and a half.
5800x/3090
Which will become the norm sooner than later from Intel and AMD as PCI-SIG and Intel are "solving it" with the new PCI-E Gen 5 spec.
Whether or not your PSU will be able to run it will probably not influenced by any limit or undervolt you do on the 4080. It's not a question of size, it's a question of Round 3 Transient spike issues. heck there's a chance no G5 unit regardless of wattage will handle it.
Just have to wait and see, and it's best to not buy any PSU whatsoever, until the 4080 actually launches. (Of course if you don't mind selling all your units used, than it's fine either way).
You are both technically correct (https://www.nvidia.com/en-us/geforce/graphics-cards/compare/?section=compare-specs), what model did you use and did you undervolt etc?
Ha, I know i'm correct, i've had this card since launch. That's what Nvidia's site has said since day 1. Its an FE model limited to 350W stock but I have the power limit removed and it sits at 400W constant under a gaming load @ 3840x1600. Not currently undervolted as I'm lazy. Says perfectly cool and maintains 1950Mhz boost.
5800x/3090
Not bad, I tend to get ~300W out of my 6900XT under normal loads.
Yep, its rated at 300W stock so that makes sense.
5800x/3090
i hope the 4080 will work with what i have right now. idk that much about transient spikes, ill look into it more. is my 750 g5 bad at handling it?
Nobody but Jensen knows xD, best just keep it regardless and try it out on the 4080, and wait until Aris (Techpowerup, Tomshardware, HardwareBustersInternational), GamersNexus reviews, general videos when it launches.
if i had to guess you'd have to undervolt it or at the very least not oc it...the spikes are rumored to be worse than ampere.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
it will probably work, with the founders edition.  but if you get the EVGA power limit modded 550w because why not merica version (tm) things might look less rosey...
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
 Share
