build Need hardware suggestions for a gaming capable physics simulation workstation
AMD has just provided some details on its upcoming Zen 4 (Ryzen 7000) desktop offerings. Up to 16 cores, 32 threads with DDR5 memory and turbo clocks over 5GHz. There will be 3 motherboard streams, the more capable offering PCIe 5.0 lanes for storage. All in all a significant uplift.
Q4 2022 should also see the introduction of new Intel CPU. Likely a refinement of its recently introduced models. Quite possibly with up to 24 cores (32 threads).
If you can wait, you will likely be able to get a significantly more capable system with the budget available.
The current Ryzen platform is at end-of-life. While still very capable, it's full upgrade path is known and available today.
If you decide on purchasing now, something like the following meets your requirements. There is a fair bit of room for a decent GPU.
CPU: AMD Ryzen 9 5950X 3.4 GHz 16-Core Processor ($548.99 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler ($129.99 @ Amazon)
Motherboard: Gigabyte X570S AERO G ATX AM4 Motherboard ($299.99 @ Amazon)
Memory: G.Skill Ripjaws V 128 GB (4 x 32 GB) DDR4-3600 CL18 Memory ($484.99 @ Newegg)
Storage: Kingston KC3000 2.048 TB M.2-2280 NVME Solid State Drive ($308.86 @ Amazon)
Case: Fractal Design Meshify 2 Compact ATX Mid Tower Case ($123.99 @ Walmart)
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($134.99 @ Amazon)
Total: $2031.80
Generated by PCPartPicker 2022-05-25 09:40 EDT-0400
