Will my power supply be powerful enough?
3 minutes ago, ExalyThor said:I suggest a 1200W Seasonic Titanium rated power supply. You should all stop assuming that just because it's not a sAsONiC or derived from one it will blow up. That power supply may not be very efficient, quiet, or capable of delivering very clean power, but it's good enough for OPs needs.
No.
Thats BEYOND TERRIBLE advice. This psu is known to have issues. It's a risky unit. If you can avoid using it do so. Op is RIGHTLY worried here as the psu itself is already blatantly lying ON THE STICKER AND BOX. So yeah this is a danger unit. Low quality and does not seem to have any form of protection what so over. It doesn't even have a 80+ rating. This is a beyond terrible unit basically guaranteed to kill a system.
Will there be people that are lucky and use this psu for a decade without issues? Probably. But that doesn't change the fact that it's a bad unit and you should NOT rely on luck.
