Burn in resistant monitors for writing/gaming
Hybris5112
Go to solution Solved by Stahlmann,
49 minutes ago, Hybris5112 said:
For burn in resistance what specs/tech should I be looking for?
Any IPS/VA/TN monitor will be pretty much immune to burn-in. There are rare cases of burn-in on these displays, but we're talking extremely rare and when it happens it's usually one specific model, basically to the point where i'd say it's a non-issue.
OLED is the only current display tech that suffers from permanent burn-in.
Is this incompatible with high refresh 4k displays currently or soon to be on the market?
Not a problem. There are plenty of 4K high refresh rate monitors.
Should I expect to budget more money to get the features I want?
No, there are plenty of good 4K 144Hz IPS monitors available for around $650 US.
A few examples are the Gigabyte M28U, Samsung Odyssey G7 LS28 and the MSI MAG281URF.
Over the pandemic I had taken up writing fan fiction and I am about to start down the path of producing something I intend to get published on Amazon at some point. However I have found my current 1440p Asus monitor suffers from increasingly annoying burn in where for example going from my word processor to the LTT forums where I have dark mode on I can quite clearly read what I had been typing for the next hour or two.
I had been milling over for sometime a 144-165hz 4k monitor upgrade but I wanted to wait for prices of panels to drop below a $1000 usd or so before pulling the trigger, but now with this new desire for burn in resistance I am not sure if I am asking for something that isn't available.
So I guess my questions are:
"The Codex Electronica does not support this overclock."
CPU: AMD 5600X - Motherboard: ASUS B550-E - GPU: RTX 3080 10G - RAM: 24GB DDR4 3600MHz CL16 - PSU: Corsair RMx 850W - Storage: 500GB boot drive + 2TB storage SSD - Cooling: custom water loop - Case: O11 Dynamic - Fans: NF-A12x25 - AMP/DAC: FiiO K5 Pro - OS: W10 Pro - Monitor: LG C2 42" - Mouse: Logitech G Pro - Keyboard: Logitech G915 TKL - Headphones: Beyerdynamic Amiron Home - Microphone: Antlion ModMic
I had an LG IPS panel that developed image retention thought.
It isn't burn in, but it sounds like exactly in this post. If i had something open for few hours, then the afterimage would be seen for like 10mins until it disappeared.
So while burn-in is pretty much impossible, image retention is much more common, but still rare, and should be under warranty.
I only see your reply if you @ me.
This reply/comment was generated by AI.
True,For example my 7 years old TN panel doesn't have burn-in at all.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
The last display I was on and noticed burn-in was plasma (yes this was in 2022...).
AMD 7950x / Asus Strix B650E / 64GB @ 6000c30 / 2TB Samsung 980 Pro Heatsink 4.0x4 / 7.68TB Samsung PM9A3 / 3.84TB Samsung PM983 / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED
Custom water loop EK Vector AM4, D5 pump, Coolstream 420 radiator
There was one particular LG ultrawide i was hearing about when it comes to burn-in on IPS. That's why i said extremely rare and typically specific to a model.
Never had an ultrawide, so it more seems like an overall manufacturer issue, and that is LG. I have seen other models from LG also develop image retention just after the 2 year warranty is over.
I have to admit that I hadn't seen that the monitor prices had dropped quite that much so this helps greatly.
