Fixing water/tea damage after two years?
Solved by ArmasF32,
3 minutes ago, Levent said:Go right ahead, you might get some experience might learn something the process or salvage something.
Yea, and even if the mobo is fucked i will probably get a working one with a broken display or something and just swap boards
Bismarck4117 ·
Posted in Laptops and Pre-Built Systems0 -
CoolJosh3k ·
Posted in Displays1 -
gsgloden456 ·
Posted in PC Gaming1 -
2
1
kacper6768 ·
Posted in Displays2 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
