Search In
  • More options...
Find results that contain...
Find results in...
PC doesn't fully power off when I do 'Power > Shut Down'
CrekYu
 Share
Go to solution Solved by Mel0nMan,
Are the correct drivers for your motherboard chipset installed? Are sleep states disabled/enabled?
For a while now my PC hasn't been fully powering off when I use the Shut Down option in the Windows start menu.
When I press Shut Down, my monitors and keyboard turn off, but my CPU fan speeds up and the lights in my PC stay on.
I have to hold the power button on my case for it to actually power down.
The real big problem I have is that it's seemingly random. Though rarely, my PC WILL turn off when I use the Shut Down button with no further actions needed.
Any help would be very appreciated, because this is one of the most annoying problems I've had with owning a PC.
Try disableling fastboot in the bios and also from power options (control panel -> power options -> change what the power button do -> change settings that are currently available -> untick "turn on fast startup")
Just checked, Windows Fast Startup was already disabled, and Fastboot in the bios was already disabled.
I'm not a professional, just an enthusiast. I don't know everything.
HGST Ultrastar: The last HDD you'll ever need to buy (and the one I always recommend).
Schrödinger's CPU: The Q9650. Is it irrelevant? Is it not?
Funny enough, this happened to me recently due to a ram defect. I used windows memory diagnostic to see which one was bad (tested one at a time after I ran it with both) and got an RMA.
It could also be a power supply defect.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
I couldn't find "Sleep States" in my BIOS (Z390 Phantom)
But I did find CPU C states, which I disabled and now it seems like my PC fully powers off...
I have no idea if that's what you were talking about, but it seems to have fixed it.
I've done a couple tests and it seems to work properly, but I won't mark it as a solution yet in case it's somehow a fluke.
C states/sleep states, same thing
 Share
