Do voice recorder and camera video recorder use the same mic? Also is the quality the same?
Go to solution Solved by Kazooduck,
4 hours ago, coollincolnboi said:
Oh so it's normal for a voice recording having a better mic quality then video recording?
And this is because video recordings are more forced on picture quality? And nothing is effected by the ejector tool right?
Totally, and yes
you also may have the mic closer to you in a voice recording, where as targets are far away in video
Hello so when you do a voice recording and video recording do they both use the same mic? And if they do will the audio quality be good?
That would depend on the device, but I assume so.
That would also depend on the device. And probably what you're trying to record, different kinds of microphones are good at different things.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
I have a samsung s21 fe. Now can you tell me?
According to this site the FE has the same triple mic setup (2 on top, one on the bottom) as the normal S21, and it's okay with normal recordings, just lacks a bit of treble and bass: https://www.dxomark.com/samsung-galaxy-s21-ultra-5g-exynos-audio-review-excellent-on-artifacts/.
As for which microphones it uses for what, I'm not sure. Samsung doesn't seem to say. I'd assume it uses the bottom mic for voice recordings, and all 3 for video as needed.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Oh so the mic quality of the video recording and voice recording be good right? Because I mistskly put the sim ejector tool in the bottom mic hole but I figured out the mic is at the side so it did not damage anything. But I wanted to ask if I record a video or a voice recording will the quality  be good? Thats my main worry lol
Thx for the help :))
Record a video and see, best way to tell. If it's personal videos/audio then so long as it sounds fine to you, it's good enough.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Yea I did it sounded good to my
Last question
Even though the sim ejector did not damage anything will the mic quality  still be good?
Thank you for the help
Last question
Sim ejector pushed into a wall in the phone, manufacturers angle the mic away now. You’re good. 🙂
check your cables!
samsung s10e | android enthusiast | Tech blogger | XC Athlete | Surface pro 4
OK thank you:) just to clarify if I do a voice or video recording the quality would be good then right?
Yes, but on samsung phones, you can pic what mic to use on voice recorder, and exporting voice files are easier
check your cables!
OK thx :)) now I know if I do a voice or video recording the quality will be good even though I put the sim ejector tool in the mic hole but it did not damage anything  🙂
Sorry if it comes of as condescending, but could you mark me as the solution instead of yours? It helps with the point system in the website. Thanks!
check your cables!
There 🙂 also I have a question I am thinking that because of me putting the ejector tool in the mic hole when I do a voice recording the mic quality is good but when I do a video recording the mic quality isn't good?
I really get worried about things is this true what I am thinking or dumb because the mic was not damaged?
I will put that answer to the solution:)
Thanks!
thats just because it uses the whole mic array for voice, where it prioritises video quality for video. its normal 😄
check your cables!
Totally, and yes
check your cables!
3 hours ago, kamonanban said:
Totally, and yes
I have the mic closer for both when did a video and voice recording.
But it's still the reason because of a video recording being focused on picture quality right? Thats why a voice recorder sounds better? And not because of the sim ejector tool right?
Sorry last question lol
Sim ejector did nothing, just uses more mics on voice recorder
check your cables!
Oh so that's why voice recorder has better mic quality then video recording?
Yep! Lmk if there’s anything else
check your cables!
Nothing else your the best!!!
The best helper thx mann!Mann!! 😊
One last thing how do you know all of this? Did you get it from a article or something and or a website can you give the link.
Watching a lot of jerryrigeverything tear down videos, and personal experience
check your cables!
