Intel dh55pj motherboard ( Issue )
That looks like a psu fault, try another spare psu if you have one
If its board fault then its either bios corruption or something has really gone wrong with that board
If its a bios fault you just desolder the bios chip, stick it on a cheap usb bios programmer like ch341a (pay attention to orientation), reflash, then just resolder it back to the board
If its not bios fault tbh id just go nuclear on it and dunk in a bucket of water after fully discharging by shorting clr cmos for 1-2 mins, and leave in bucket for an hour or 2, then when you take it out dry it as much as possible by shaking it around and leave for 2-5 days, also works with ultrasonic cleaner and dishwasher but idk how to do it on dishwasher. that looks like the kind of problem that isnt easy to locate so just go nuclear on it, pretty much what i did after one of my garbage g31 i bought couldnt be fixed even with multiple dousing of 99% IPA so dunked in water and boom fixed
If the board is a dud then its worthless garbage anyways since you cant overclock with it and 1st gen needs to be overclocked if you want any sort of performance out of it, tops id expect that board to sell would only be like 20$
