Search In
  • More options...
Find results that contain...
Find results in...
I just plugged a 3 pin fan header into a 4pin fan header and somehow still have full control over
 Share
Go to solution Solved by Skiiwee29,
You're controlling it via DC voltage, not PWM signal.
I plugged a 3 pin fan header to a 4pon header how do I still have control over it, as I have seen that you can't, just curious if anyone can explain, thanks :)
PSU Tier List Thread | Community Standards | Fan Control Software
"Black Out"
Ryzen 9 5900x | Noctua NH-D15 | Asus Crosshair VIII Hero (Wi-Fi) | RTX 3090 Founders | Ballistix 32gb 16-18-18-36 3600mhz
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Phanteks Enthoo Evolv ATX | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
It’s being controlled directly by voltage, ie you’re seeing the system provide more or less power to the motor directly rather than by using the PWM signal to control fan speed.
PWM allows for RPM accurate measurement and speed control, voltage controlled fan speed isn’t tracked accurately and doesn’t have an accurate stepping.
 Share
