Assign ip from /29 block to virtual machines
4 minutes ago, Nik schaad said:Im aware of all of those problems, this is a long term idea and all that im currently looking for is a few links and references as to how I can tunnel the ip's from extraip to my servers. I want to figure out how it all works and how I can do it before I start to worry about the next part (s). Do you by any chance know how I can tunnel them. Idk what ip mapping is, as I said im still learning. Do you have any links where I can learn these things?
Ok, that's a bit more level headed, I'm more used to people just wanting to print money because someone else does it kind of thing, lol. So if you're not planning to jump into the deep end then that's much easier to help you with
For tunnels it depends on what ExtraIP supports but doing some research you'll need to setup a GRE tunnel at minimum. You could setup a VM to act as the tunnel on your side and have it form a tunnel with ExtraIP. The biggest issue with all of this is there isn't a single guide for it, there are thousands which vary depending on what you use as the tunnel endpoint.
Mapping is basically using PAT(many:1) instead of NAT (1:1) to host multiple machines behind a single IP. Basically how your home internet allows multiple things to connect behind a single public IP. PAT in this case would be 1 machine to 1 IP on a specific port or range of ports they can use. Again though this is a million ways to set up kind of deal but all depends on how ExtraIP has their stuff setup.
Topics to research:
PAT/NAT
GRE Tunnels
IP logging/security (probably a bit broad but at least start with logging)
General resources:
cisco.com
juniper.com
stackoverflow.com
google.com
