Search In
  • More options...
Find results that contain...
Find results in...
putting 120mm gpu aio at rear as a intake.
can i put my gpu aio as a intake at rear fan mount? i have liquid cooled rx 6900xt and my cpu cooler is dark rock pro 3, i have 2 140mm intake fans and 2 120mm top exhaust fans, gpu aio is at rear as exhaust. i just wanna turn the fan over for intake. is this good idea or not so good idea? dust is no problem for me, i clean pc often
What direction is your CPU cooler blowing air? The last thing you want is your CPU cooler and radiator being right next to each other, and blowing air in opposite directions.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
CPU is blowing in direction of gpu, so blowing back.
then I don't recommend putting the AIO as intake
Primary PC:
 Share
