Search In
  • More options...
Find results that contain...
Find results in...
GPU Fans running at 80% in Apex.
c3524
 Share
Hi all,
My GPU which i only got a few weeks ago running at nearly max fan speed when playing Apex legends. This only occurs every few days and will also do it randomly for a few seconds when i have the game running in the background. Temps do not exceed 70 degrees. Any ideas what may be causing this?
Specs:
GPU: Asus Dual OC 6600 xt
CPU: i5 11400
RAM: 16gb Corsair LPX 3200 cl 16 using xmp at 3200 mhz
Motherboard: Asrock B560m Pro 4 a/c
PSU: Corsair CX550M
OS: Windows 10 Education
SSD: Crucial P2 500gb
55 minutes ago, c3524 said:
Hi all,
Specs:
CPU: i5 11400
PSU: Corsair CX550M
The fans just doing their job.
AMD FX™ 6300 @ 4.51 GHz | ASUS M5A97 R2.0 | Sapphire Radeon HD 7850 2GB OC | 24GB Kingston DDR3 | Samsung 850 EVO 250GB WD Green 1.5TB | ASUS Xonar DG | Windows 10 Pro
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5  | ASUS ProArt PA238QR
Intel Core™ i7-7600U | Seagate 500GB HDD | 16GB DDR4 | Windows 10 Enterprise | HP EliteBook 850 G4
Intel Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 8GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance DDR3 | Samsung 850 EVO 250GB | macOS Catalina  Lenovo IdeaPad P580
iPhone 12 Mini (iOS 15.4.1) | iPhone XR (iOS 15.4.1) |  iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X
But there should be no reason for them to be running that high. Every other time the fans run at about 35% in game which keeps the temp fine. But constant 80% is completely overkill and extremely loud.
try repasting GPU.. ?
or just follow this video, download the software linked in describtion from github and set it up with more delay?
Sounds like the default software is doing what its supposed to. Download a program and force them to run lower under load and see how that works out for you.
Main RIg Corsair Air 540, I7 8700k, ASUS ROG Strix Z370-H, G.Skill TridentZ 32GB, EVGA 1080TI SC Black, EVGA 850 GQ, Acer KG251Q 1920x1080@240hz
Spare RIg Corsair Air 540, I7 4770K, Asus Maximus VI Extreme, G.Skill Ares 32Gb, EVGA 1080sc & 1060 SSC, Corsair CX850M, Acer GD235hz 1920x1080@120hz
why would u recommend touching it physically without any probable cause?
i suggest opening monitoring software like HWinfo64 (not sure how good it is on AMD GPU) and see if anything seems off
-sigh- feeling like I'm being too negative lately
Thanks everyone, ill have a look into some monitoring software. Cheers.
Set a fan curve so it doesn’t happen
R5 5600x, b550 gaming carbon Wi-Fi, 32gb Corsair rgb pro, 2x1 tb WD black nvme, 2tb WD black hdd, Corsair rmx750, Amd 6700xt, be quiet dx500
Glorious model D and gmmk compact
Dell s2721dgf
Xbox series x
 Share
