Armory Crate Ruining Wireless Bluetooth Sound Quality on ASUS ROG MAXIMUS Z690 HERO
Solved by GuiltySpark_,
21 minutes ago, cleric_warlock said:I installed armory crate to do driver updates...
This is where you went wrong. Garbage software that really can screw up your system with all the stuff it installs and changes. Its also entirely unnecessary for installing drivers, your motherboards support page is all you need and there are only a couple.
The official uninstall tool that will remove far more of that software plague than just uninstalling it with the built in uninstaller: https://www.asus.com/support/FAQ/1041654/#1-2. How to uninstall Armoury Crate
Even after running that you'll have leftover windows services that it adds.. its truly terrible.
