Best Audio interface for an AT2020
Solved by Entropy.,
1 hour ago, cat milker said:Hey all, I'm pretty well versed in PC's in general, but I was a little confused when I wanted to start making music. My friend bought me an AT2020 mic for my birthday. I was looking at an audio interface on sweetwater for it, and before I buy it I wanted to make sure it is compatible. I'll list both here
umc202hd is a solid interface, functionally the umc22 will be the same, minus support for two mics and one or two small features. Yes, it will work, though.
