Help diagnosing/troubleshooting a monitor
Link to video of the monitor's problem
I got this monitor (MSI Optix MAG281URF) about 6 months ago. Roughly 3 months ago what you see in the video started happening. From my perspective, it is completely random when it happens. I have tried new cables, ports, and different inputs (PC and console). Any advice is very welcome! Thanks!
That does look like a dying monitor. Since the problem happens with a pc and a console it is not the connected device. And you have checked cables.
Thanks for your quick reply! Cables are all connected properly and I have tried swapping out for others to no help. However, timing is something that is inconsistent. Sometimes the monitor will go out a few minuets after turning it on and other times it will be weeks between occurances.
