help me find my modem firmware
Alireza
hi
i recently upgraded my internet to a rock solid fiber connection and im pretty happy with the service in terms of speed and latency
but there is something going on that's driving me insane
every 47-48 minutes the connection will drop for 5 second and then it will get reconnected
the PON light will stay on and LOS light is also stays off but the internet light will turn of for a few second
and after reconnecting my ip will change too
i talked to my isp and they factory reset the modem and reconfigured it remotely but that didn't fixed it
and then they told me there most be something wrong with the modems firmware
and then i thought i may just update the firmware since i didn't done it the moment i bought it but i cant find it anywhere
its a Fiberhome AN5506-04-F running version RP2609
i don't even know if its the latest version or not
i cant buy another model since my isp told me Fiberhome is the only brand there equipment work with
and i cant buy another unit because there too expensive in my region
can you help me find the firmware or even solve the problem?
or should i contact my isp again and say something else
this connection drop realllllllllly mess with my gaming/streaming session
also i connected with a ethernet cable to it
You in almost all cases cannot as the firmware is managed by your ISP for the units. I would call your ISP and tell them that your connection is constantly dropping and have them check for errors on the link if possible, there might be a small cut in the fiber somewhere just enough to be causing some weird issues but not stopping the connection completely.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
i bought the modem and i have complete control over it
its no problem in that case
they should send a technician to solve the problem, even if you own the modem.
Act like got no clue.
I own my cable modem but I have no control over its firmware, only the cable provider can push updates to it.
my ISP ddoesnt control the modems
i have admin access to it
Your ISP does control the firmware,
I have admin access to mine too but I still can't find or upload firmware. It's there as a last resort when firmware is provided by the ISP to the customer which almost never happens.
Prior Build Log/PC:
Having admin access is not the same as not needing the firmware from your ISP. If they use the same modem they should be able to provide you with their latest firmware. From what I can tell there is at least a RP2669 firmware out there. But I have not been able to find anywhere public to download it.
You really need to badger your ISP regarding them providing the updated firmware. If they can remotely factory reset and configure your modem, then they can also update the firmware. They probably have a specific firmware for their network as well
well i did always update the firmware myself on my old internet since in my country ISPs don't care about these stuff
also we don't have coax cable internet and lets now focus on my problem
can anyone help me finding the issue assuming asking the isp to come over is not an option or help me find the firmware?
yeah im aware they have some control but they dont update firmware or change any setting on routers
as soon as internet is connected
there done
i cant find the FW either
i dont know where else to look
1) That's a fiber ONT just like you have, different model same concept
2) The firmware is supposed to be managed by your ISP, it's not something you just download off the internet. They are responsible for it and I spent 30 minutes searching and found nothing and I wouldn't trust random files on the internet anyway, I'd want official firmware from the manufacturer but their site also requires a support contract to download, again, something your ISP is supposed to deal with.
Prior Build Log/PC:
This modem is not something that is sold to end-users for liberal use on any fios connection. This is something your ISP requires you to use because they are using the same one. You need to get them to provide their firmware for this modem. If they know you have the wrong/too old firmware for their network then they also have a later version available. They will probably not send you the file, since you can then upload it to the interwebs. That means they have to install it for you and stop being dicks about it.
2) The firmware is supposed to be managed by your ISP, it's not something you just download off the internet. They are responsible for it and I spent 30 minutes searching and found nothing and I wouldn't trust random files on the internet anyway, I'd want official firmware from the manufacturer which doesn't seem to exist. Their site also requires a support contract to download, again, something your ISP is supposed to deal with.
damn it
thats a let down
im in university in another city and i only come back home for weekend when they wont send technician
if anyone knows way to get my hands on a firmware
contact me please
On my fibre modem (huawei) there are 2 types of admin, regular admin (user controlled) and superadmin.
Superadmin have different username / password and can control everything from signal tweaking to firmware update.
my advice is just call them to send technicians, since they recommended the modem, they should be familiar with it.
most of the time problem like this is not related to the modem.
i had similar problem a couple of months before, the signal drops every 10 hours.
they send technician, turns out theres a problem with their hub, after some tweaking, problem disappear.
i live in iran
international rules doesn't apply here and ISPs doesn't provide hardware to end user except for TD-LTE equipment's
that's really helpful
seeing someone else having the same issue is kind of a relief for me now
although i know about that super admin on HW routers but there is no such thing on Fiberhome Routers
still apparently i need to contact them again for the like a thousand time until they fix it
3 minutes ago, Alireza said:
i live in iran
Considering you live in Iran, there is slim no chance that we can help you with the hardware you got. These are not international rules either, these common ISP practices.
i know
that's what i meant
for now if anyone could help me further in my side of the connection it would be much appreciated
i live in iran
All I am saying is that if they require you to use a specific modem for their network, which is a model that is not meant to be sold directly to end users. They need to provide a working firmware for it. Otherwise they are requiring you to use a non-working solution. Which by any rules, international or not, is by definition not a solution.
The only other option I can find is to contact the manufacturer directly: https://en.fiberhome.com/default.aspx
But I am unable to find that modem model or any firmware for it there. So you'd have to attempt the support email listed in contact information.
yeah, act like you don't know anything, don't say you can use the admin, you just want it to work. this might help you go up the urgent list.
theres no such thing as 'fiberhome router", everything modem related usually made by the same usual company like siemens, motorola, huawei, zte etc.
after all the effort to contact them failed, just go with another ISP.
ill do that
sadly there are the only Fiber providers
  • 1 month later...
hi
small update for you guys
after several days fighting with ISP
it is finally fixed
after 2 weeks of calling them repeatedly
i got an unexpected call from the ISPs local supervisor and he thanked me for reporting the problem (i was confused at the moment)
then he explained to me what was the problem
turns out there own router was responsible for all the session drops and lags (apparently it was overheating)
after a few days they informed me that the problem should be fixed
right now the connection hasn't been drop for about a week
the modem and the firmware was fine
