How to set up Gsync properly? (Gsync compatible monitor)
Mark Kaine
I know I should limit the framerate in NVCP 2-3fps higher than the refreshrate, correct?
Is that it? Why is it necessary?
I also read some people use RTSS instead to limit the framerate,  what's the difference,  setting it in NVCP seems less of a hassle?
Im just asking because last time I tried this nothing really worked, like it literally felt like Gsync stopped working after a few minutes,  if it even worked at all...
So i bought a new dp cable now in case that was at fault but I don't want to make any mistakes now and set it up properly?
Its a mag 274qrf, 165hz, but I want to use it at 120hz...
GPU is 3070 vision OC (specs is profile)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
2-3FPS LOWER not higher than the refresh rate.
Because the frame limiter is not perfect and there is some variation.
You also need to both enable VSync and Frame limiter.
You wont get the VSync latency this way and it is required for perfect tearless experience even with GSync/FreeSync (usually there is still some tearing near the bottom of the screen if you leave VSync disabled).
You dont have to do any of that. I just enable gsync compatibility mode in NVCP then enable vsync in games, my monitor also has a feature where it shows me which mode its working (so that I can see freesync is enabled) and also has another option to display output HZ so that I know it matches the game FPS.
There is also this gem.
https://www.testufo.com/gsync
Lower, not higher. If you have a 144Hz display for example, limit FPS to 142 or so. GSync does NOT work if you're rendering frames higher than your displays refresh rate.
Older method, NVCP didn't always have this function. I agree, i'd much rather do it right in Nvidia's own software.
Some people swear by enabling VSync in conjunction with GSync but I despise that as I still feel the induced "lag" from VSync being on.
https://blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/14
Except as they say in your linked page, that ONLY applies to "some games" that triple-buffer when vsync enables.
If you set a frame rate limit in those games, then you're sorted.  VSync only kicks in when going over the maximum refresh rate.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Oh, ok... well i don't remember anymore if i did this wrong also when i tried,  but its possible...
in NVCP? In game i turn Vsync off then?
I definitely noticed that... works and then doesn't...  -.-
I mean, i tried that (minus the Vsync initially) and it didn't work properly...
I guess i should try again though just in case it was the cable?
Also maybe i need to update the firmware or something... guess i have to check that too. 🤔
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
I've had a Gsync module display (PG348Q) for nearly 5 years now and have never bothered wtih VSync. Simple framerate cap 1-2fps under the max refresh rate and its been great for every game.
Which I never want to happen so yeah, i stick to just capping games which is easy now that its built into NVCP.
V-sync is not required to turn on for me as well in game or in NVCP.
Now using 240hz monitor with VRR, not even need to bother framerate cap 1-2fps as they is no games I can play over 200fps. 😅
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
That works too. 🤣
And why is it doing this all the time?  Its really annoying lol...
i dont understand why doesn't it stay either at 120 or 60hz? Since this game is locked at 60fps... nothing i can do other than turn off Gsync?
I still don't understand when the refresh rate is tied to the framerate,  what on earth makes it go to 120hz then? This game runs at 60fps... lol.
Cant turn on or off Vsync either btw
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
NVCP is more convenient but not the best. Sometimes the in-game limiter gives the least latency, sometimes the RTSS is better... but I personaly just use NVCP because I'm too lazdy to do research on game to game basis...
I dont think it matters much whether you use in-game VSync or the one from NVCP since you won't be hitting the max refesh rate of the monitor because of the frame limiter and thus avoid the VSync latency penalty.
Lol, this is really weird... when i turn off OBS it does this...?
looks different right?
And I know what ya'll gonna say, why play a 60fps game with Gsync ... and you're right, except it does the same thing when a game runs at 100fps... it just doesn't feel smooth when the refreshrate is always higher than the framerate... (i remember i had that happen with 100fps and 165hz... it always jumped between the two)
Well Im going to try to limit framerate  now with another game...
ok I see. and yeah i tried that before without Gsync, there isn't much difference between NVCP and ingame Vsync.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Set it 118fps... Vsync is on...
Horizon Zero Dawn:
Shouldn't the refresh rate be at least somewhere close to the framerate?
It just stays at 120hz .
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
These are the steps i accumulated over the years to make G-Sync work perfectly and for pretty much any game:
Start off by enabling VRR in your monitor OSD if there is an option. Some monitors need it to be manually enabled for the first time.
In Nvidia driver:
- turn on G-Sync for fullscreen only (fullscreen AND windowed makes tab-out times a lot longer in my experience)
- go to the 3D settings header
- set preferred monitor technology to "G-Sync compatible"
- set the fps limit to your refresh rate (i tried everything from 0-5 fps lower than refresh rate it never made a difference as long as you cap it)
- enable V-Sync
(- while you're here, also set low-latency mode to ultra, there is no reason to leave this off and it improves latency in GPU bound situations)
In-game:
- turn off V-Sync
- set game to fullscreen (or exclusive fullscreen depending on what the game calls it)
- disable any in-game fps limiter (or set it to something higher than your driver fps limit when you cannot disable so the driver can do the work)
Using these settings i never had any tearing, stuttering or input lag issues when playing any game. I tried these on everything from non-cerified FreeSync monitors, G-Sync compatible ones, native G-Sync and G-Sync Ultimate.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Honestly I tried all that... I really thought its the dp cable perhaps,  but now i bought another one and its pretty much the same as with the old cable that came with the monitor...
Like it ("gsync") will work for 5 minutes (if that) and then simply stops working,  i kid you not as in the screenshot above it literally got stuck at 120hz for example even tho framerate was around ~70fps.
And even if it "works" its stuttery as heck,  sometimes the picture just stops moving... I'd be better off with intel hd graphics and no "gsync"...
you're right, it may or may not happen when alt tabbing, but it also happened simply by pressing the record hot key for OBS ...
But it also just randomly can stop working,  as said typically after 5 minutes (whereas i want to emphasize it may "work" but its still stuttering... i literally tried without Gsync and unrestricted framerates that felt actually smooth in comparison)
So i unfortunately cant really tell if thats just how gsync is supposed to work , or if indeed something is broken with the monitor or gpu... i mean it just feels *very* laggy and Im better off not using it,  which is a shame because why did i then pay for a "gsync compatible monitor "... feels like scam! ¯\_(ツ)_/¯
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
And even if it "works" its stuttery as heck,  sometimes the picture just stops moving... id better off with intel hd graphics and no "gsync"...
you're right, it may or may not happen when alt tabbing, but it also happened simply by pressing the record hot key for OBS (delete) ...
There is definetly something wrong. If anything, VRR (G-Sync) makes the image smoother, not more stuttery. The fact that your monitor displays static 120Hz refresh rate while it should be syncing says that VRR is not on for whatever reason. If VRR is in fact on, the refresh rate and fps should always be one and the same.
that is what Ive been expecting and how gsync is advertised,  but it never actually is...
you think updating the monitor firmware would help? I mean its the last thing i could try before possibly doing an RMA...
And btw, i did turn on vrr on the monitor first, so that's not it either.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Could be a firmware issue. Updating might help if this monitor actually supports user-side firmware updates.
And btw, i did turn off vrr on the monitor first, so that's not it either.
Why would you turn off VRR if that's what you want to use?
yeah i think it does..  I'll give that a try.
typo lol.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
