Buying my first pc - from POWERGPU.. helppp!!
Solved by Jorgemeister,
19 minutes ago, jaslion said:Buy the parts and contact a local shop to build it for you. Common solution.
Or follow a tutorial on yt. It's pretty easy as long as you take your time.
Either way you were getting seriously ripped off with the prebuilt system from that place.
Also in all honesty you could trim about 5-800$ from the current system recommended to you and not even notice a difference in any of your tasks.
Totally agree with this.
Some stores you buy the parts from can charge a fee to assamble it for you. Or just go ahead and watch some videos and do it yourself, its a very rewarding experience.
Good thing you asked, 4.5K for a system with a GPU from 2018 is kind of a scam.
