Question about BIOS Fan Setting & AIO
Solved by Hairless Monkey Boy,
15 minutes ago, Poinkachu said:What kind of setting should I use in my fan settings in BIOS ??
Should i switch it to Auto? PWM? DC?
Should I turn off/on Smart Fan setting for it (CPU Fan)?
It doesn't matter, I'm pretty confident that the "3 pin cable" connected to the motherboard has only 1 wire populated, the sense wire. It's only purpose is to report the fan or pump speed to the motherboard.
You control the fan and pump speed in iCue.
