What storage, RAM, case for a Ryzen 5600G build
I guess we never answered your other questions:
1 hour ago, Mighty_Dork said:Question 1: Is this logic sound? Does this build make sense then?
I'd say so, but the 5600G will perform significantly worse than the 12100F + 1050Ti in games. You'll need to do the research yourself, if the performance is still good enough for your liking.
1 hour ago, Mighty_Dork said:Question 2: What storage would you recommend? The one on the list was picked by the guy helping me, is there a better value option? Like same price, slightly less speed but noticeably more space?
Not really, $40-$45 is about the cheapest you'll find 512GB SSDs, and higher capacity SSDs are pricier. Just get whatever SSD is the cheapest you can find, NVMe is preferred, but SATA is not bad either.
1 hour ago, Mighty_Dork said:Question 4: Just any good case recommendations, this one is expensive isn't it? If it's worth it then ok, it's worth it but that's my question, should I get something else?
The "big name" PC case companies (like Lian Li, Corsair, Fractal Design, NZXT and so on) that are available globally tend to be more expensive. You don't need a high airflow case with a 5600G, even when you're adding a 3060 later. You probably got this recommendation, because it's something that's available everywhere. You can look around for brands that may be local to your market, or maybe you can buy from german resellers, decent budget brands available in Germany are Kolink, Inter-Tech, AeroCool. Pick something you like that doesn't have a completely closed off front. If you like something small, you could look into the CoolerMaster Q500L.
