Who has had their Seasonic PSU replaced by Seasonic due to RTX 3080/3090 shutdown issue
hamilton21017
 Share
1 hour ago, freeagent said:
For some reason I thought it was all of them 😄
Same.  Both AX850 and AX1000 had issues with Ampere and those both leverage the Prime Platinum.
FurMark+Prime95SmallFFT
Tested with 8xMSAA,XtremeBurn-in
Runs more high-load tests
Continues to give me no shutdown errors
Using a 850W seasonic, but with the 6900XT, no issues so far 🙂
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
14 hours ago, hamilton21017 said:
Gentlemen? Wait a minute. I think you have misunderstood something.
I did not exchange it and bought a new one from AMAZON.
The reason is that I could not exchange it.
What was the reason that you couldn't use warranty for your first PSU with the issue?
Jesus, what a long annoying thread.
Dude, think of it like this.  People start to have problems with the power supply, and RMA them or open tickets which are passed by the tech support people to the actual engineers.
The engineers test things and talk directly to the people and maybe suggest sending a replacement cable kit instead of RMAing the heavy power supply, as a TEMPORARY measure. The support people are out of the loop, they no longer know what happens. Because it's a temporary or case-by-case fix, the engineers don't update the documentation that's sent to the people who answer support tickets (people who could be in a totally different office or who may even be employees of a third party company answer tickets for multiple companies).
So a short while later, they figure out what to tweak in the power supply, maybe a resistor or maybe they add an extra capacitor or a ferrite bead on the 12v sense wire, a minor change, and from that point when people RMA power supplies, they do this fix and send the power supply back with the original cables.
Nobody lies to you, I don't think they do.
The distributor doesn't know, and doesn't get updates from Seasonic about such fixes.
The support people that answer to tickets can only tell you the "official" line ... they open up an internal wiki or some database, look for the power supply model and they don't see there anything mentioned about "replacing cables", so they answer to the best of their knowledge that there's no policy or any rule telling them about replacing cables.
The cable replacement temporary solution offered directly by engineers maybe never got through all the way to the support ticket answering people, or they may even not be allowed to admit that cables were sent, because maybe they don't want to establish a precedent or something like that.
You got pictures here showing which wire is the sense wire, so you could easily buy a pin extractor tool and pull out that sense wire, and test your power supply with and without that sense wire installed in the connector.
4 hours ago, Sleepycat3 said:
この問題で最初のPSUの保証を使用できなかった理由は何ですか?
They responded that they did not have "everything" in the original item I returned. Perhaps I was missing "something" that I needed. Here is the answer.
And I was forced to buy a "new" June 2021 model.
I bought "new" as they said.
They, Seasonic, owe me support.
I'd like to add.
I have not removed any cables from the case.
I only replaced the unit, so the cables are still there.
I bought the new one on Steam, Sniper Elite 5.
This game seems to require more "GPU performance".
It's over 10GB at 1440p ultra setting....
Guess I got the game to check for possible shutdowns!
This game will put a reasonable strain on the GPU.
Was this Seasonic global? Or the local seller in Japan? That's is so odd. My experience in my country, Seasonic through their local service partner/distributor said to send back only the PSU. No cables, no box, no bag.
After they tested for a few weeks (3-4 weeks from memory), they then sent me a brand new sealed box PX-850. So I actually have 2 sets of cables now, but I won't mix and match since they are from old (2018) and new (2021) versions.
I agree...
This starting to somewhat feel like a crusade or witch hunt.
What makes it worse for me is that the OP doesn't have any qualm about using people's name without permission.
While I can understand if it's about stuffs blowing up, but that kinda thing will surely make enough ripple and noise throughout the whole community.
Possible shutdowns......., me, i'd rather just buy another PSU from another brand if I don't trust it enough that it won't do shutdown.
And just like @Sleepycat3 said, if RMA is still possible, I'll RMA it until I can no longer RMA it. xD
Edited by Spotty
Refresh before you reply
Unfortunately, the distributor in my country requires that all accessories be 100% complete for replacement. This may vary from country to country.
This is why I took out a hardship and took out a 24 loan to purchase the unit. The current power supply requires a commitment not to shut down. Reason for sticking with it.
You may not be able to read this because it is in Japanese, but "Owltec", the Seasonic distributor in my country, has finally acknowledged the circumstances of this shutdown.
<Japanese translation>
Thank you very much for using our products.
We are very sorry for the inconvenience caused.
We also apologize for the time it has taken us to confirm your inquiry.
Regarding your inquiry about PRIME-TX-850, we have received a response from SEASONIC Co.
We would like to inform you of the following.
(1) When a SEASONIC power supply unit is used in combination with a peripheral device with large power consumption, the protection function in the power supply unit may work in rare cases.
 protection function in the power supply unit may be triggered, causing a shutdown or other symptoms.
 (1) It has been reported that when SEASONIC power supply units are used in combination with peripherals with high power consumption, the protection function in the power supply unit may be triggered in rare cases, resulting in a shutdown.
(2) If this symptom occurs, the product will be replaced.
 The product warranty is in accordance with the product warranty policy.
We do not accept any response regarding compatibility with specific peripheral devices.
We have heard that the product you are currently using does not cause shutdowns.
However, if the problem should occur under other conditions in the future, we would be happy to assist you.
However, if the problem should occur under other conditions in the future, we apologize for the inconvenience, but please contact us.
Please also note that the PC environment used for the operation verification by OWL-TEC is as follows.
The following information is provided for your information. We are sorry that we cannot accept reports on test results or additional test conditions.
We are sorry, but we cannot accept reports of test results or additional test conditions.
Here, take a look.
From past 2022/03/22 23:16:19 until 2022/05/28 12:55:17 A.M.
100% no trace of the shutdown exists.
This is the best evidence we have.
I have experimented over and over again with various tests that can be reproduced.
This thread has run its course and there's not much potential for this to progress further. As per the OP they are not experiencing this issue and Seasonic has replied offering an explanation. Allowing it to go on further is just a witch hunt.
OP: if you're not experiencing any problems with your power supply then I suggest you move on and just use your computer. I'm sure you bought your PC for reasons other than complaining on forums about issues you aren't even experiencing. Stop worrying about it and go play games or edit photos or whatever it was you bought your PC to do.
Guest
 Share
