IcyDock 5.25 slim ODD, 3.5 bay mount
da na
Bought this a few days ago and thought I should post a review, as it is quite the useful adapter.
As a bit of backstory, I used a USB card reader with a 5.25 to 3.5 adapter, and had my DVD writer in the other bay. Bought a SATA hotswap dock for my 5.25 bay and sacrificed the USB card reader as I needed the optical drive more. But it's pretty inconvenient using a dongle, so I looked for solutions that didn't involve moving the DVD drive out of the case as desk space is limited, and I found this adapter from IcyDock allowing you to use a 9.5mm/laptop/slim ODD AND a 3.5 hard drive, floppy, or card reader in a single 5.25 bay. This seemed practical since I just needed the drive, how fast it was didn't matter too much (laptop optical drives are usually 1/3-1/2 the speed of full size ones). Adapter was $20 (DON'T buy it on ebay, buy it on Amazon, I bought mine on ebay and realized when it arrived the seller had just dropshipped it from Amazon and I paid $20, $5 extra, for it.) I already had this optical drive but they can be found for under $10 (get one with a bezel) on ebay.
Quite easy to install and to install devices into, instructions are good. Feel of it is alright, despite it being all plastic. My one complaint is that if you tighten the side screws in the 3.5 bay too much it squeezes the plastic part below the 3.5 bay and it sticks out a bit, so don't tighten the screws all the way down, it won't fit in your case. I would haved preferred a smooth plastic since, as you can see from the picture, its textured plastic matches nothing else on the case but that's a trivial complaint.
It also includes the adapter to adapt full SATA to laptop optical drive mini SATA, so you don't need to buy that separately. Adapter does feel a bit cheap, but come on it's like 2 amps max, shouldn't be a problem.
I'd say it's a decent adapter if you want to save a bit of space.
Something like could be very useful for me, although not right now but rather in the future. I'm old-school and like having ODD's and card readers, but most cases don't support them anymore. My Node 804 accomplished half that task with its slot-loading drive, but I still have to dig out dongles for SD cards.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Bought one of these a few weeks for £15.49 from UK retailer Scan (around $20 including Tax). It does the job but unlike 10-15 years ago it's basically the only choice in the sub-$20 range as no-one makes adapters like this anymore. Personally speaking the optical drive bay could be slightly lower while still leaving space for 3.5" devices but it works well enough.
As for why I bought one... I built a computer for my parents and they wanted to keep a DVD drive in the new computer. Because of that I went with the Thermaltake Versa H15 as ir has a 5.25" bay... but it's useless for a standard full-sized DVD drive, as anything longer than155mm in length hits the motherboard, and in my case the 24pin power socket of the motherboard... and every full-sized DVD drive I have or could find online is at least 165mm long.
It's a viable alternative but it's more a lesson that just because a case advertises a 5.25" external bay, it doesn't mean a standard optical drive will fit. Definitely not happy with Thermaltake for that one,
US Gaming Rig (April 2021): Win 11Pro/10 Pro, Thermaltake Core V21, Intel Core i7 10700K with XMP2/MCE enabled, 4x8GB G.Skill Trident Z RGB DDR4 @3,600MHz, Asus Z490-G (Wi-Fi), SK Hynix nvme SSDs (1x 2TB P41, 1x 500GB P31) SSDs, 1x WD 4TB SATA SSD, 1x16TB Seagate HDD, Asus Dual RTX 3060 V2 OC, Seasonic Focus PX-750, LG 27GN800-B monitor. Logitech Z533 speakers, Xbox Stereo & Wireless headsets, Logitech G213 keyboard, G703 mouse with Powerplay
UK HTPC #2 (April 2022) Win 11 Pro, Silverstone ML08, (with SST-FPS01 front panel adapter), Intel Core i5 10400, 2x8GB Corsair Vengeance LPX DDR4 @3,600MHz, Asus B560-I, SK Hynix P31 (500GB) nvme boot SSD, 1x 5TB Seagate 2.5" HDD, Drobo S with 5x4TB HDDs, Hauppauge WinTV-quadHD TV Tuner, Silverstone SST-SX500-LG v2.1 SFX PSU, LG 42LW550T TV. Philips HTL5120 soundbar, Logitech K400.
US HTPC (planning 2024): Win 11 Pro, Streacom DB4, Intel Core i5 13600T, RAM TBC (32GB), AsRock Z690-itx/ax, SK Hynix P41 Platinum 1TB, Streacom ZF240 PSU, LG TV, Logitech K400.
US NAS (planning): tbc
UK Gaming Rig #2 (May 2013, offline 2020): Win 10 Pro/Win 8.1 Pro with MCE, Antec 1200 v3, Intel Core i5 4670K @4.2GHz, 4x4GB Corsair DDR3 @1,600MHz, Asus Z87-DELUXE/Dual, Samsung 840 Evo 1TB boot SSD, 1TB & 500GB sata m.2 SSDs (and 6 HDDs for 28TB total in a Storage Space), no dGPU, Seasonic SS-660XP2, Dell U2410 monitor. Dell AY511 soundbar, Sennheiser HD205, Saitek Eclipse II keyboard, Roccat Kone XTD mouse.
UK Gaming Rig #1 (Feb 2008, last rebuilt 2013, offline 2020): Win 7 Ultimate (64bit)/Win Vista Ultimate (32bit)/Win XP Pro (32bit), Coolermaster Elite 335U, Intel Core 2 Quad Q9650 @3.6GHz, 4x2GB Corsair DDR3 @1,600MHz, Asus P5E3 Deluxe/WiFi-Ap@n, 2x 1TB & 2x 500GB 2.5" HDDs (1 for each OS & 1 for Win7 data), NVidia GTX 750, CoolerMaster Real Power M620 PSU, shared I/O with gaming rig #2 via KVM.
UK HTPC #1 (June 2010, rebuilt 2012/13, offline 2022) Win 7 Home Premium, Antec Fusion Black, Intel Core i3 3220T, 4x2GB OCZ DDR3 @1,600MHz, Gigabyte H77M-D3H, OCZ Agility3 120GB boot SSD, 1x1TB 2.5" HDD, Blackgold 3620 TV Tuner, Seasonic SS-400FL2 Fanless PSU, Logitech MX Air, Origen RC197.
Laptop: 2015 HP Spectre x360, i7 6500U, 8GB Ram, 512GB m.2 Sata SSD.
Tablet: Surface Go 128GB/8GB.
Mini PC: Intel Compute Stick (m3)
