Search In
  • More options...
Find results that contain...
Find results in...
Fans going to fast
Tyler121604
 Share
I have a cpu fan that spins fast. It has 3 pins connected to a 4 pin on the motherboard which is an asus prime b560m-a ac. I tried changing the mode from pwm to dc in bios but it doesn’t let me. I also tried speedfan and Ai suite 3 but I am not too sure how those work.
In the BIOS, instead of changing from PWM to DC, change the speed by dragging the points on the chart lower
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
I tried that but it doesn’t change the speed
It is a 3pin fan connected to 4 pin on motherboard which means it can’t use pwm
CPU fan is still goin fast
when you set the "silent" profile for every fan, and then restart the PC, what happens?
Primary PC:
The cpu fan stays the same speed. The fans on the case I can control it is only the cpu fan that I can’t.
Does this still happen if you use a different header for the CPU fan instead of a system fan?
Primary PC:
 Share
