Search In
  • More options...
Find results that contain...
Find results in...
I have. EVGA nu audio pci sound card but windows won’t install drivers. Any help?!
Srius1
 Share
So it’s installed and sata power connected but for some reason the damn thing isn’t being detected or installed by windows! Does anyone have info about why this would be the case ?
edit: fixed! I was using a sata splitter from my psu to my sound card and another device. I removed the splitter and windows detected it and it worked! Guess you can’t use splitters as universally as I though!
  • CPU 12900k   Motherboard Asus z690 prime RAM 32gb gskill 3200 trident z GPU Msi suprim RTX3080 wekwb block Case 011 dynamic PSU Evga gq  850w 1tb NVME m.2 boot drive
Have you gone to device manager and checked there?  Right click on the start menu and select it, check for any yellow triangles next to a device
Cans                                          Amps                                                               Speakers                                      Mic
Sennheiser 6xx                          Topping DX7 (dac/amp) (class D balanced)     Micca RB42                                  Antlion ModMic Uni
Beyerdynamic DT880-600         Emotiva A-100 (class A)        Vmoda Boom Pro
Phillips Fidelio X3                      Nobsound Little Bear P7 (pure tube)                 Accessories                                Neego boom mic
Harmonicdyne Zeus                   Little dot MKII (pure tube)                                  Dekoni, Brainwavz and ZMF pads
Fostex T50RP                            Darkvoice 336SE (pure tube)                            Hart and Periapt cables
HiFi-man HE400i (2017)            Crown XLi1500 (power amp class A)                Yoga Blocks (headphone stands)
Blue Microphones Lola               Xduoo MT-602 (class A hybrid tube)
Koss KPH30iCL                          Schiit Fulla (class D dac/amp)                          Headset
AKG K-361-BT        Turtle Beach Stealth 700 v2 + adapter
Phillips shp9500
AKG K240 studio
Yes it says “base device audio”and has a error box next to it
screen shot of that?
Phillips shp9500
AKG K240 studio
right click that and try to uninstall, reinstall disable re-enable update etc
*edit: you can use the snipping tool to take screen shots.  Windows key + shift + S  and select the area you want then click the popup in the bottom right and save the image
Phillips shp9500
AKG K240 studio
Did you find a solution?
Phillips shp9500
AKG K240 studio
Yes! Was a sata splitter that was causing the issue. I took it out and it detected right up and works awesome.
 Share
