USB (Hub?) for charging multiple USB-C devices at the same time.
Eighjan
Hi,
I have a phone AND a tablet that both use USB-C to charge & was wondering if such a device exists that can, when the occasion requires, charge both at the same time?
As far as I know, the pair wouldn't need more than 25w combined - based off the mains adapters that they're supplied with.
Thanks in advance.
PS If this is in the wrong place, can a Mod. please move it to the correct one.  TYVM.
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
12 minutes ago, HanZie82 said:
That would work... but a UK Amazon link would be nicer.
TY.
WHY NOT...?!
TY.
Ah yeah i just guess, but copying the title name and posting it in your local Amazon search bar might work. 🙂
I'll be honest, "Charging Station" never occurred to me... but I looked on Amazon UK & found a gadget for £8 w/ 3 ports & 3 short A-C cables.
TY for the 'extra brain' to get it sorted... have a "Solved".
WHY NOT...?!
You're welcome, very glad you found what you needed this fast. 🙂
