Retro Sleeper Build
Shadowlyn
Just wanted to share my Sleeper PC that I finished yesterday.  Inspiratuon came from watching some of the retro builds on the channel.  Case was a ATX case that I bought in 1999 for my first PC Build.  Purchased from Multiwave while stationed in Okinawa.  Only modification was that i had to drill a hole in plastic fan case so cord for new coolmaster 80mil fan could reach mother board.  Ran Cinabench and PC test on GPU UserBenchmarks and all thermals were great.  The only thing left is to order an adapter to get the floppy drive to work.
Parts:
AMD Ryzen 5 2600x
Asrock B450 Pro4 AMD AM4 ATX Motherboard
Inland Premium 512GB SSD M.2 INTERNAL
Seagate Barracuda 2tb 7200RPM Sata III 3.5"
Zodiax 1050TI
PowerSpec 650 Watt 80 Plus Bronze ATX Semi-Modular PSU
EverCool Dual 5.25in drive bay with 80mil fan.
C-Zone 3.5 Floppy Bay 3.0USB/Audio Jacks
Pics 1-3 prebuild
Pic 4 finished build
I have a suggestion, scrub your case with chlorine bleach and it will be as white as factory new.
An Helpdesk IT guy from China, English is not good.most of the replies are translated into English using Google.Although I have repaired many PC, my answer may still be wrong.Please let me know if I make a mistake.PLZ,answer me let me know!!!
Bleach sounds like a win, I might try that on my old pre 2000's cases.
I heard that some kind of tooth whitening gel, plastic bag, and sunlight would do it. Sounds weird though.
PC1: Intel i7-6950X | EVGA X99 FTW | EVGA RTX 2080 XC2 Ultra | SBZ | ATH-M40x | 760T | Sapphire Pro 14 | G815 | Dark Core |
Drives: 970Evo+, 980, SN750EK | 850Pro | 6x1TB RAID0 | WD RED 4TB | WD Blk 2TB | WD Blue 4TB
Displays: (2) ASUS VG278Q | (2) ASUS VG279Q | (1) Vizio 40" 4K HDR
Build Log: https://builds.gg/builds/raid-red-rtx-ws-14981
It was never White it has always been a Beige or an Off white with Dark Gray trim.  The damage to the inside was due getting a few inches of water from a Hurricane when the house flooded.
  • 2 months later...
