USB for B550-e Bios update? Help pls :D
Hey,
I have a suspicion I’ll be needing to update my b550-e bios in order to use my 5900x and was wondering if I should be using a USB 2.0 stick or a newer one?
Also, I’m mostly certain however just in case I’ll ask; does the stick need to be formatted as FAT32 ?
Thanks for the help in advance,
Lex.
The drive does need to be formatted as Fat32.
The usb revision doesn't matter as all usb versions are backwards and forwards compatible with each other
