gtx 970 memory clock at 3005 instead of 3505 help
Mu-To
Hi everyone, my name is Muto and I'am the big fan of linus and new to this forum. nearly 1 month ago my gpu (msi gtx 970 gaming 4g ) memory downclocked to 3005mhz from 3505(base clock). I tried to set to back 3505 with nvidia inspector, but after restart it goes back to 3005. when i clean install the driver it works at 3505, like nvidia inspector after restart it goes back to 3005. also I checked it on windows startup. when windwos starts after 5-7 seconds it downlockes itself. 4-5 month ago I tried it overclock to 4005 mhz and it was working well, then I reset the factory setting, used oc for 20-30 min. I wonder now if my gpu is dying?
thanks for help
Do you have the downclock saved to a profile and it kicks in when Windows starts after the program loads?
