My 3000mhz ram is only running at 2400 is there something wrong
Solved by getdown,
you need to press delete during the asus splash screen, usually tapping delete while your system boots is easiest way to get to BIOS
He sets docp in an Asus BIOS at the start of the vid, the benchmark part is optional
https://www.youtube.com/watch?v=TuqNMwb9pB0
Set DOCP, and the find the option for save and restart, should be pretty straight forward
